Please help!
I have a Beovision 9, and have connected a Projectiondesign projector to display 2, DVI-D out. I have an DVI-D to HDMI converter both on tv and projector.
When press format 0 on the Beo4 the picture on Beovision 9 closes, and the sound still works perfect.
The problem is when I press format 0, this message on the projector appears:
"WARNING- CONTENT IS PROTECTED- SELECT ANOTHER SOURCE"
I have try to connect my projector directly to Apple TV, and this works great. The problem is I need to use my Beovision 9 as speaker. I have been thinking maybe to use a HDMI splitter on my apple tv, and the "picture mute" on the TV. Then it could work fine?
PLEASE HELP!
Thanks!
Hi Stuart,
thanks for responding!
This is an Beovision 9 MK1, so this is one of the first models of this in the marked. If there is an HDCP issue, can it be solved by an opgrade of Beomaster 3? Can I by my self do this upgrade, or does it need an autorised Beo dealer to do this?
I have tryed out socket 1 also, but same problem appears. I have try the cable on a different setup, and there are no faults on the cable.
