Avant stuck in timer mode and remote frozen
This post has 3 Replies | 2 Followers
rumad4it2
Posts 2
rumad4it2 Posted: Wed, Dec 26 2012 11:44 AM
Hi all I have an old but fabulous Avant however it is stuck in timer mode and my remote seems to be frozen I have changed the batteries in the remote with no success can any one help please before my wife losers her mind and suggests I buy a Samsung. John in Sheffield, UK
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Wed, Dec 26 2012 11:58 AM
Try plugging it out and leave it a while. Then see if you can turn it on using the button on top of the Avant. Likewise with remote, leave the batteries out a while. Let know hoe you get on.
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Wed, Dec 26 2012 12:51 PM
If by timer mode you mean you've got a 'Wait' message then you've had the Avant unplugged for 30+ minutes (or the mains power has been off) and have got the PIN wrong three times (unless the PIN function has been disabled.)
So if unplugging and getting a reset does not work, try plugging back in and leaving the power on. After about an hour (?) you will be able to try the PIN again.
If you have just acquired your Avant the previous owner should have given you the PIN, failing which, with proof of ownership, a B&O dealer should be able to help.
Graham
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Wed, Dec 26 2012 2:42 PM
If you mean that the red LED is constantly lit on the display at the top of the cabinet. Have a look behind the word "Play Timer". You will see a button. Just press this to take the Avant out of timer mode.
Opman
Page 1 of 1 (4 items) | RSS
