I have investing in a couple of B & O products, but have trouble getting them to work together.
I bought a Beovision 4 with Beosystem 2 and a Beolab 3500. I have connected Beosystem with BeoLab with a Master Link, and hoped that it just worked together, but it didn´t.
I have searched in various manuals and on various forums, unfortunately without being wiser.
It seems as if there are not at life in the Beolab - however, there is light and time in the display - but no sound.
The TV turns off when pressed on the Mute button on Beolaben, so the Beosystem and the Beolab must be connected ?
The TV shows the picture and channels - but no sound.
In "Sound" in the TV menu, Beolab 3500 is not an option.
Has it something the "Options" settings?
I really hope that someone here can come up with a suggestion for a solution - thank you in advance:-)
With the tv on, press "link" followed by "tv".
This send the tv sound to the Beolab 3500, and you can control the sound.
But I think that the Beolab 3500 only can receive analouge sound, not digital.
Press "link" followed by "tv", and you should get the sound into the Beolab 3500.
I think it only accepts analoge signals, not digital.
Hey,
Thank you very much for your answer.
With press "link" I guess you mean "link" at the beo4 (after it has been added to the display) ?
I tried that, and "tv" shows shortly at the display at the beolab, but dissapears again after a few seconds ?
Now, as befor, there are just 2 red dots at the display at the beolab ??
Something wrong with the beolab ?`
/Janus
