Does the earset 3i control support the last generation of ipod nano (7th generation)?
This post has 2 Replies | 2 Followers
hispano
Posts 4
hispano Posted: Mon, Jan 14 2013 4:18 PM
Hi guys!
I want to buy the earset 3i but I plan to buy the ipod nano too so  I would like to know if the control (volume, pause, play...) of the earset 3i works fine with the last ipod nano 7th release.
Thanks!
Ricardo
Michael
Sweden
Posts 2,578
Michael replied on Tue, Jan 15 2013 1:15 PM
Hi Ricardo,
Yes this will work and you can use the microphone to record voice memos. At least it works with the Apple Earpods with remote and mic and therefore it should work with EarSet 3i since it uses the same technology.
I have used my EarSet 3i with my iPod Nano 6th generation while running and it also works.
//Michael
hispano
Posts 4
hispano replied on Tue, Jan 15 2013 2:28 PM
Many thanks!  I just wanted to be sure before buying this nice but expensive earphones.
Page 1 of 1 (3 items) | RSS
