Hi all
I need the small round plastic feet that go on the underside of the Beolink 1000 and the Beolab 8000 terminal.
Does anyone know if these or suitable replacements are available?
Regards
John
Perth WA
I bought from my local dealer the last time, I needed some.They may still be available from B&O, have you asked ?
The feet for Beolink 1000 were still available from B&O not so long ago - I suggest you ask your dealer first, they weren't even expensive!
I have used patches of self-adhesive black felt on the bottom of some of my remotes. Very friendly to all surfaces and will last forever unless you make them too small.
--mika
Got you this time, Mika !
Thanks for all your help. Have ordered them from the local B&O service cost 33 cents each.
