Newbie so be gentle!
Beogram CD 50 and Beocord 5000 tape deck.
CD drawer opens with a very slight pull on corner of tray and CD plate ejects. Put CD in tray and CD closes.
Display shows a number 1 and then CD tray is trying to open and eject CD.
CD obviously doesn't play. Any ideas?
Tape deck lid lifts and closes OK. Fairly loud constant buzzing noise and whether cassette is inserted or not, spools do not rotate.
Again, any ideas?
Thanks in anticipation.
Jacques
Yes Jacques.
