BV 75 NG/Mark2 studdering
f5434964
Austria
Posts 206
f5434964 Posted: Sat, Aug 10 2019 11:30 AM
dear Friends of Beoworld
My BV 75 NG/Mark2 works great but once a week it decides to take a Break; already done: Software Update - Login with android account to make sure that Update of Android Apps is done
The TV sometimes seems to studder- it does not react properly nether with Beoremote nor beoapp over wlan; change of Volume, Starting Apps (YouTube), EPG - everything takes seconds
doing a Hard reset by Power cut and restart seems to help for some time - so I think the TV itself lacks of RAM or the processor is busy with ... ?
does anyone has similar Experiences?
sorry for my spelling - written on iOS
best regards elmar
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Sun, Aug 11 2019 10:10 AM
Hi, I have same experience with my Horizon, it slows down a bit after some period and either I have to pull the mains or the TV is rebooting / crashing at its own and resets itself.
Android TV seems to be the problem, the Android OS is not that good but the multiple software updates have made the TV’s much more stable now. Only this problem and occasionally crashing still remains.
I do not expect large improvements of the software anymore from B&O. Android TV itself is on a higher OS now which will not come available for B&O.
Android was a bad choice for B&O unfortunately.
f5434964
Austria
Posts 206
f5434964 replied on Tue, Aug 13 2019 5:23 AM
f5434964
Austria
Posts 206
Page 1 of 1 (4 items) | RSS
