Hi everybody.
I was wandering if any of you could recommend me an infrared volume control for my active speakers, so that I can use my Beo5 to turn the volume up and down?
At the moment I'm using a NanoPatch, but it has no infrared receiver, so i have to turn the volume up and down manually.
I hope that some of you have some suggestions, bellow I have attached a picture of what I'm using now.
All the best
Niels
Hi Niels,
More details would help everone help you.
What is your current set-up? what speakers are you using? are they connected to B&O? B&O do a few things that would probably help but without the full detial of what you have and what you are trying to do, we would only be guessing
Stoobie
Ask Revoxbeo they probably have a volume control for BEO
Regards
Hi again.
My speakers are actually not B&O, but Genelec.
My setup is very simple. I have two active speakers connected to a volume control, to were my CD and MP3-player is connected.
My question is: Do you guys know a good and reliable volume control, to where I can use my Beo5? It might be B&O or it might be some other brand.
did you ask Revoxbeo ?
