VCR VX8000 CASSETTE LOAD MECHANISM GETTING STUCK
This post has 1 Reply | 0 Followers
brunetto77
Posts 35
brunetto77 Posted: Sun, Jan 27 2013 1:52 AM
MY VX8000 HAS RECENTLY DEVELOPED THE PROBLEM THAT THE TAPE WILL NOT GO FULLY INSIDE AND GETS STUCK SOMEWHERE IN THE MIDDLE. SOMETIMES IT IS DOES THE OPPOSITE WHEN A TAPE WILL NOT COME OUT AND STILL GETS STUCK IN THE MIDDLE. I OPENED THE UNIT IN ORDER TO REMOVE THE TAPE AND TRIED TO LUBRICATE THE TEETH WHEELS. THIS HOWEVER HELPS FOR A VERY LITTLE TIME AND THEN THE PROBLEMS REAPPEARS. WHAT DO YOU THINK THE ISSUES IS AND WHAT CAN I DO? I HAD BOUGHT THIS SECOND HAND BUT NEVER HAD A PROBLEM BEFORE AND THE UNIT LOOKS NEW.
THANKS IN ADVANCE FOR YOUR TIME
brunetto77
Posts 35
Any idea? Anyone? Unsure
Page 1 of 1 (2 items) | RSS
