HOW TO CONNECT BEOLAB 5 WITH A PREAMP ( LINN )
This post has 4 Replies | 0 Followers
andriani
France
Posts 85
andriani Posted: Mon, Mar 19 2012 6:33 PM
Hello,i am newbie
I would like to connect my new beolab5 with a preamp ( Linn) to listen SACD ( for example)
Today my beolab5 is connected by powerlink  to beosystem 3 included in my beovision 7_40
I would like to know if this procedure is correct:
             1  for analogique ( LINE)
from my preamp for example
       rca left  -------> line beolab 5 left
do i have to connect with "syncr" between the beolab 5
what option if i have to stay also with beovison 7 ?Unsure
       2  for  digital
   from my preamp
               digital out ---------> digital IN beolab 5LEFT
and then digital OUT beolab 5 LEFT -------------> digital IN beolab RIGHT
thanks for your adviceSmile
andriani
sorry for my english i write from south of france
andriani
France
Posts 85
andriani replied on Fri, Mar 23 2012 5:51 PM
no answer please helpSad
carlito
Posts 239
carlito replied on Thu, Mar 29 2012 8:24 AM
Hi Andriani
I had made the same experience with the Beolab 5. The major problem they have is the digital inputs opens only if the command “CD “ is comming through the Powerlink connection. I use my Beolab 5 in Option 4 and feed them most from my macmini where all my lossless sound is stored. I have several digital players, so i use a Cambridge DacMagic Plus as “digital hub”.
You have 2 options – here Option 1:
-       Connecting the Beolabs with Powerlink, and the digitalcables direct to your LINN CD-Player
-       You have to put in a CD in your DVD (BV7-40) that the Beolabs open the SPDIF Input.
-       Cons: You have the workaround with having a CD in the DVD drive...
Option 2:
-       Connecting the Beolab 5  with RCA cables to your TV (Beosystem 3)
-       The digitalcables direct to your LINN CD-Player
-       Set the Beolab’s to Option 1 or 4 (if you don’t have a Radio in your Setup, Option 1 works)
-       Cons: You have to control the Volume from your speakers independent from your TV setup
Hope this helps.
Regards
Carlo
andriani
France
Posts 85
andriani replied on Thu, Mar 29 2012 5:46 PM
thanks carlo
 i have try this way and it works in "analogic"
                           1 I connect my LINN AKURATE DS ( stremaing music) to my preamp LINN KISTO in RCA
                           2 I connect  each beolab 5 ( LINE) to the OUTPUT of my preamp by RCA
                           3 I can choose
                                            OPTION 1  on beo4 ( RADIO) -> i see the volume on my beovision 7 and can control IT
                                             OPTION 4 on beo4 ( LINK and then RADIO, you can read how to in the manual) -> i can control the volume by preamp
I have tried in DIGITAL( all the connection befor in digital,digital output from my PREAMP LINN) but i HAVE JUST in BEOLAB 5 a " rose noise", but in reading your message i haven't do CD in my BEO 4
I shall try it
But i can say that in "analogic" the depth of the music is deep : i think the union of LINN/BEOLAB 5 is very very beautiful ( five stars)
I listen the same music with beosound 5/BEOLAB 5 but it lacks of aerial depth transparency ( fours stars)
I would like to compare in digital way , i am not sure it will be best
i shall try to connect DIRECTLY as you said in your message : the PREAMP LINN (RCA)----> BEOLAB 5 ( POWERLINK), THe beolab 5 have TWO powerlink, if i let my BEOVISION 7 on the powerlink 1 can i used in the same time the powerlink 2 for the preamp LINN
THANKS Smile
good to listen musicBig Smile
andriani
France
Posts 85
thanks for your idea and tips about how to connect a preamp on beolab5Smile
Page 1 of 1 (5 items) | RSS
