Any good
This post has 11 Replies | 1 Follower
Orava
Finland
Posts 991
Orava Posted: Thu, Feb 14 2013 6:27 PM
Any experiences
mbee
Paris, France
Posts 1,842
mbee replied on Thu, Feb 14 2013 7:49 PM
Not masterlink compatible (as all Beoplay products)
no aluminum
Lack of HDMI plugs... And no boomerang functionality.
So I have to conclude that by Beoworld standards, this Beoplay product is a complete crap!
But usually people buying Beoplay products are quite happy with them, so you can consider a try.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Feb 14 2013 8:40 PM
I think it looks a little cheap and "plastic" - but the design is clean and functional, and connectivity with "hands" and "canines mouths" will be excellent I'm sure.
All in all, an engineering "triumph" according to Tue and the marketing team ....
Big Smile
Orava
Finland
Posts 991
Orava replied on Fri, Feb 15 2013 7:11 AM
mbee:
no aluminum
Big Smile Yes, it cant be controlled with Beolink 1000, and I guess this is not made to be  High-End device, so it might have high wow&flutter values, as some other brands I have tried.
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Feb 15 2013 7:57 AM
I think its a product that will really take off.
//Bo.
A long list...
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Feb 15 2013 8:16 AM
Bos00:
Laughing
It might fall flat on it's face shortly after takeoff, though. It's a small difference between Scheibe and Scheiße...
--mika
Vik
Amsterdam, the Netherlands
Posts 3
Vik replied on Fri, Feb 15 2013 9:14 AM
Mixed feelings about this one.
I used to own one. Operation is pretty simple. I found however, that you need a large living room for it to function properly. Also be careful with really cranking it up - it might damage your speakers. And vases.
badgersurf
Posts 539
What the chances that it is not hand built in Struer but mass produced in China!
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan replied on Fri, Feb 15 2013 10:36 AM
It's the latest turntable by B&O Play!
x:________________________
StUrrock
Posts 995
StUrrock replied on Fri, Feb 15 2013 1:11 PM
Is it made of the same quality plastic as the PlayMaker? Ick!
Andrew
Frinton, UK
Posts 917
Andrew replied on Fri, Feb 15 2013 1:28 PM
What is it?
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Fri, Feb 15 2013 1:51 PM
A Frisbee toy. Made in China. I have One. Bad Plastic Quality - too soft. Bad branding for Beo.
Page 1 of 1 (12 items) | RSS
