Beocenter 9500 & equalizer or another use of the in/out
Limbabnees
Posts 21
Limbabnees Posted: Sun, May 12 2013 8:40 PM
How connect and use an equalizer on the Beocenter 9500.
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, May 12 2013 8:44 PM
Welcome to the forum!
You'll need a special connection to the DIN LINE IN/OUT socket just above the POWERLINK 1 socket on the rear connections panel.  Normally the IN/OUT connections are bridged with the plug that is usually inserted.
EDIT:  Checked the service manual and I think pins 4 and 1 are R and L out respectively, whereas pins 5 and 3 and R and L in.  Pin 2 is ground.
Can't think why you'd need an equalizer though!
Limbabnees
Posts 21
Limbabnees replied on Sun, May 12 2013 10:30 PM
Thanks.
I thought so, but wasn't sure.
Dont need an equalizer, but i have a Missing Link Musical Fidelity (Tube).
Just want to check how it will sounds.
Page 1 of 1 (3 items) | RSS
