Hi guys just got my apple tv so here is my question
Download a rented film once completed can play now or save for later. to save for later have to bring up menu what command is used on beo4 to bring up the menu so I can save the film for later
many thanks
Malcolm welborn
malcolm welborn: Hi guys just got my apple tv so here is my question Download a rented film once completed can play now or save for later. to save for later have to bring up menu what command is used on beo4 to bring up the menu so I can save the film for later many thanks Malcolm welborn
Hi Malcolm, if I understand the question correctly, simply purchase / rent the show, and when prompt for "now or later" hit the exit key to take you back a level.
Then when you are next in "movies" or "tv shows" you will see on the right hand side of the top menu line something like "purchased" or "available".
Select that, and you will see the list of "saved" items.
It does not actually "save" as in "copy to disk" since the latest ATVs have no discs; it just "remembers' that you have a purchase / rental that you have not yet watched.
BeoNut since '75
hi there
many thanks for the info
cannot believe its nearly a year since struer
hope you both well
malcolm
malcolm welborn:cannot believe its nearly a year since struer
yes - amazing whirlwind since then
malcolm welborn:hope you both well
yes we are thanks, trust you are well
"family" keeps growing - one live in girl friend - and a separate first grandchild - all part of the whirlwinds
