I have had to update my failing old sky+ box, and sky have gave me an hd + box, now my bv3 will only scroll thru there menu etc , and i am unable to use digits to choose a channel i.e press 301 and nothing happens ......is that me now having to collect remotes again or is there a fix........ah nuts
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
In the BV3 set up for decoders, there are 2 Skyboxes listed.
12 Sky Digital
47 Pace Sky+
Could be you need to change to the other listed decoder.
I have just installed a Sky multi-room HD box which works well on No47
Ron
HI there
you need to get the PUC control for SKY HD they are different than the SKY+ box
im not sure the BV3 has the PUC for SKY HD
look for thompson HD in your list.
Your dealer will be able to tell you if your TV can be flashed with a new PUC or if it has a chip - you might be able to have a HD PUC installed but it depends on the method of updating and if it was availible.
as a last resort you could use a lintronic
Eclipse 65V1-32Beosound M5Essence MK2BLI
Have done it ....... control with all function, pace sky+....works...now to bin the sky+ buttons
