Hi
BEO4 pixels missing
Put a new screen and still the same problem.
Anyone fixed this ??? or pcb has to be changed.
You could try cleaning the display contacts on the PCB (where the zebra rubber of the LCD presses onto), but if it doesn't help I'm afraid it's time for a new PCB.
You didn't touch the rubber connector while replacing the display, did you? The tiniest amount of grease from the fingers might be enough to prevent it from working.
--mika
The screen and rubber are new from B&O, and no I was very carefull and pixel defect was the same as before with old screen
