I wanted to activate the HDMI matrix function to add HDMI ports on a BV 7-55, as I did many times on other BV x-xx TVs, but now it is asking for a 12 digit key when I'm trying to activate.
The firmware of the TV was updated recently.
Is this a joke or does B&O now charge to obtain a key if you want to activate the HDMI matrix function? I can't believe this!
Anyone had the same issue?
There was always a charge for the HDMI matrix. You might be thinking of the HDMI expander.
Yes, indeed. Mixed up both.
Thanks for the quick answer.
