Beoplayer Update
This post has 2 Replies | 2 Followers
Raeuber
Germany
Posts 2,542
Raeuber Posted: Wed, Mar 6 2013 7:45 AM
Good morning!
There is an update for Beoplayer available in AppStore (1.3).
This update is still not especially for IPhone 5 and IPad.
I installed the update on my IPads and my old IPod touch (2nd gen. with IOS 4.2.1). On IPads it works fine, but on IPod touch the app doesn't start anymore! So don't install the update under IOS 4.2.1 because downgrade is not easy or impossible!
Because of this and still no version for IPhone5 and IPad: Shame on you, B&O (also because Beoplayer App is not for free, but very expensive)!
Regards
Räuber
badgersurf
Posts 539
Thank you for the heads up with this, had updated beoplayer on my phone and was just about to do my old itouch, glad I saw this first as I use the itouch every day with beoplayer and would hate to loose it from there.
Toby
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Mar 7 2013 9:42 AM
Hi Toby,
I was glad to found the file with the old beoplayer app on my computer, so I was able to downgrade the app with an instruction I googled. The only use of my old IPod touch is connecting to Beoplay A8 and using beoplayer app, so if downgrade wouldn't be possible, my old IPod touch would be useless.
Räuber
Page 1 of 1 (3 items) | RSS
