Does anyone know if the Beogram CD X Compact Disk Player is compatible with the Beomaster 3300 receiver ?
I used to have a CDX. It has a pair of phono outputs. I used a phono to DIN converter to connect it to the Aux connector on a BC2200. There is no remote or data capability on the CDX but it does have quite flexible programming capabilities
Hi Johnmissell,
Welcome to Beoworld!
Yes it is, but the Beogram CDX has an RCA cable and will need an RCA to 5 pin Din adapter (like this).
Though the ideal match would be a Beogram CD 3300 that can be directly controlled by the 3300 Terminal and the Beomaster 3300.
Marc
