Beovision 4 65" HD?
JoshuaClark
Posts 9
JoshuaClark Posted: Wed, Mar 6 2013 6:31 PM
I'm looking at buying a Beovision 4 65" but I'm not sure if its HD ready (720) or full HD (1080). The serial number is 19541883 and it comes with the BeoSystem 3. Also does any have an idea what this would be worth? Any help appreciated!
mjmedlo
Posts 922
mjmedlo replied on Thu, Mar 7 2013 12:23 PM
Depends largely on whether its 1080 or 720
Also, is it an ACM model?
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Mar 7 2013 1:52 PM
At that serial it will not be an ACM (curved bezel) version.
I'm going to stick my neck out and say that with that serial number it'll be a 1080p flat bezel.  If it is, the type number should be 9033.
Lee
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Thu, Mar 7 2013 2:15 PM
The serial number quoted above is a BeoVision4 65 type 8993. This means it is a Mark1.
Opman
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Mar 7 2013 3:17 PM
A man with access to ROS - you're one up on me..  LOL  -  Thank you Opman.
With a BeoSystem 3 feeding the screen it won't be too bad a PQ though.  If it's cheap, go for it.
Lee
mjmedlo
Posts 922
mjmedlo replied on Thu, Mar 7 2013 9:24 PM
I gave $10.5k for a demo 65 with ACM.
Thought it was reasonable
JoshuaClark
Posts 9
Thanks a lot guys that's a big help. Well it's £3.5k with beosystem 3 and a 7.2 - what do you think?
jkhamler
Posts 286
jkhamler replied on Fri, Mar 8 2013 11:03 AM
Very good value compared with the original price, obviously that's because it's a huge, bulky, power-hungry and increasingly antiquated set which probably has limited appeal to most buyers.
Still for the money it should make a pretty impressive home cinema system if you've got the space! The 7:2 sounds great.
Chris Townsend
Qatar
Posts 3,531
What connections does it have and how can you utilise them ie dvi hdmi?
Page 1 of 1 (9 items) | RSS
