Hi all, I have a beosystem 2500 that was working fine untill my 2 year old decided to spray a bottle of glass cleaner through the doors, so i dried it off and it all worked apart from the bottom row of buttons on the keypad so being quite technical i took it apart to clean it but now none of the buttons work?
what i would like to know is there anywhere where i can get a replacement keypad membrane from or anyone who has a faulty system and willing to seel the front panel?
cheers
Kind Regards
Mark
Bought this part (contact foil) for 35GBP incl. shipping from Simon at AVA services
Brengen & Ophalen
Leslie-
I have the same problem - none of the keypads works. Is it easy to replace the foil (membrane)?
Does anyone know a place where I can order this part in the U.S.?
Thanks.
