BeoCenter 9000 RECORD lamp
Piaf
Victoria, British Columbia Canada
Posts 2,639
Piaf Posted: Mon, Apr 22 2013 5:20 PM
When the CD player is selected on my BeoCenter 9000 the RECORD lamp illuminates. Is this normal?
The manual specifies how to record and how to stop recording, but says nothing about the RECORD lamp being on.
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century,  S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase,  B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Apr 22 2013 5:42 PM
On my BC9500 the record lamp is on whenever there is a recordable cassette in the compartment - in case you want to select this function.
Piaf
Posts 2,639
Piaf replied on Tue, Apr 23 2013 4:03 AM
Thank you Guy.
Can anyone else confirm that the RECORD light only indicates that recording is available not that it is going to do so?
I am concerned that when playing a CD it might record on my cassette tape without my wish to do so.
I am more familiar with the recording feature of the Beocord 8004 and 9000 where you have to select record, check the levels than press record again.
Jeff
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Since only available functions are lit, what would you press if you wanted to record a CD?
The safeguard is that having pressed record once, the system goes into record/pause mode, you will need to press record again to actually record on the tape!!
I am sure that the user manual can be found somewhere in our database!
Regards Graham
Piaf
Posts 2,639
Piaf replied on Tue, Apr 23 2013 6:58 AM
Hi Graham,
I have now the User Manual and as I mentioned it explains how to record and how to stop recording. What was not mentioned was the RECORD light illuminating.
Manual in hand I am still experimenting with the program functions of my 9000 and I merely trying to make sure I didn’t accidentally set the 9000 up to record on one of my “precious” cassettes by mistake. That’s all.
Jeff
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Apr 23 2013 7:42 AM
Piaf:
Remove the protect tabs from any "precious" cassettes. Problem solved Smile
--mika
BO
Halmstad, Sweden
Posts 728
BO replied on Tue, Apr 23 2013 7:43 AM
If you are worried abut that you should just make the cassette record protected by removing its plastic tabs.
//Bo.
A long list...
Piaf
Posts 2,639
Piaf replied on Tue, Apr 23 2013 4:06 PM
Perhaps I used the term “precious” by mistake; treasured would have been a better choice, however removing the tabs is an excellent idea. (That was done ages ago….)
Jeff
Page 1 of 1 (8 items) | RSS
