The config tool upgrades the firmware automatically. If the tool terminates during the first step of the download, it is likely a problem of the configuration. Try the follwing: load the configuration, skip to step "edit", press the "validate" button. If the tool terminates, then its a problem of the configuration.
If you are familiar with the configuration.xml you can try finding the problem editing the xml. Otherwiese it will be the easiest way to build a new configuraiton.
hfat
