Hi can any one help I'm having a little problem with a beocom 2 which cuts out after a couple of minute when on a call can any one suggest anything to try.
Is the battery quite old? May need replacing.
I'd guess battery Jenette
Jonnie
Not sure I bought it and resold it so don't really know but what they are saying is when they use it it cut off after a couple of minutes and makes a buzzing noise, I havn't a clue, can you change the battery.
Hi Jonni thank's for your reply I don't know as I bought it and resold it he says it cuts off after one or two minutes and sometimes makes a buzzing sound can you change a battery in these.
It is a job done in most stores at it needs a special tool to remove it. It can be a diy job but you need to be careful.
I think I'll give that a miss, I don't mind doing the batteries in a beocom 6000 and beocom 4 but sounds to fiddlely for me, I know my limitations
If I remember it is about £20 to £30 to have one replaced.
Morning Jonnie, I'll check with b&o this morning
Jenette
I so much for your £20-30 just been on to b&o £100minium!!!!!!!!!!!!!!!!!!!!! I thought so b&o don't do anything cheap
Sent you an email Jenette!!
