Beosound 5
This post has 4 Replies | 2 Followers
eddie1lancs
Posts 23
eddie1lancs Posted: Sat, May 11 2013 5:53 PM
My Beosound 5 keeps playing one track and then stopping, anyone any ideas? It says 'pause' on the beosound screen if that helps?
Cheers
Vienna
make an educated guess
Posts 1,090
Vienna replied on Sat, May 11 2013 6:32 PM
eddie1lancs:
If "DISABLE MOTS is "ON"  = MOTS DISABLED and you select a "TRACK" and press "GO" the BS 5 does
exactly what you ordered it to do -  it will play a single TRACK and stop afterwards.
If you want to play the complete "ALBUM" move the album "back to the inner circle" by pressing  ">"
then press "GO" to select the ALBUM to play the complete album from the beginning.
eddie1lancs
Posts 23
I think Mots is on, in the settings menu it says 'disable Mots' and I have it set to 'no'. At the moment I can't get it to play anything, it is stuck on Pause, very strange?
w5bno123
London
Posts 578
w5bno123 replied on Sat, May 11 2013 11:44 PM
If the music has only just been loaded then it hasn't had time to populate. The MOTS calculation duration is shown as a % at the bottom left of the screen when you playback a track. Leaving the system in standby speeds up the process.
eddie1lancs
Posts 23
No it's not that either, I ripped a cd last weekend but it has been playing it without issue since then. Thanks for your help though!
Page 1 of 1 (5 items) | RSS
