Hi All,
I had Sky Q installed yesterday but because the Beovision 7 lacks HDMI ports and the Sky Q box is connected via HDMI to DVI, I only have the picture but no sound.
I have been advised that I can buy an "Audio Breakout Box" and connect this via RCA Cables but is this the right solution? Also is an Audio Breakout Box the same as an "Audio Converter - HDMI to HDMI + Audio"?
Many thanks in advance.
Jake
Have you set the sound on Sky Q to Stereo.
I have a Beovision 10 and it doesn't support dolby digital so this would probably be the same for the Beovision 7?
DVI only carries picture, not sound.
jwarren23mile:I have been advised that I can buy an "Audio Breakout Box" and connect this via RCA Cables but is this the right solution? Also is an Audio Breakout Box the same as an "Audio Converter - HDMI to HDMI + Audio"?
Yes that is the right solution - I use one of these: https://www.amazon.co.uk/aoeyoo%C2%AE-Analog-Converter-Digital-Extractor-White/dp/B00NAJ4UM2/ref=sr_1_45?dchild=1&keywords=audio+extractor&qid=1611786666&sr=8-45
You then feed the audio into the L&R PC inputs (red and white phono sockets)
