How god or bad is B&O:s Own SPDIF-cable (the thin one)?
Sweden
Posts 357
Silver Member
Martin Posted: Tue, May 7 2013 9:29 PM
I am using B&O digital cable between My Beosound 5 (Beomaster 5) and My Beolab 5. It is à very thin cable if you compare it with fine High-end digital cables (S/PDIF). Is it worth to upgrade this cable to à more expansiv one?
Regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Playdrv4me
USA
Posts 477
With analog cables you can sometimes make the assertion that thicker, better insulated cables will provide better results in video and audio. However, when speaking of a cable that transmits signals in the digital domain, so long as the cable has not been damaged in any way, there is no real improvement in spending more for a "bigger" cable. The 1s and 0s are still getting there just the same in the thin cable as the thick one. The cable you are using is fine.
Page 1 of 1 (2 items) | RSS
