Suitable DVB-C receiver for Avant
Michael
Sweden
Posts 2,578
Michael Posted: Mon, May 13 2013 9:37 AM
Hello!
I have a Beovision Avant 32 RF DVD that currently has a Dilog DVB-T receiver connected and it works well with the set top box - controller. The problem is that I have DVB-C in my home. I use a small DVB-T antenna but it works very bad and I can not see the paid channels with that.
I was thinking about buying a Thomson DCI 1500G from Germany over ebay but I am not sure it is compatible with any codes in my PUC list. It has a Thomson DTI 1000 in it and they seem to have the same remote almost, it differs just a bit. But I know it might not work.
Anyone who knows? Or can recommend a good box? I need one with a coax SPDIF, otherwise I would have bought a samsung that I know works. I can use a converter but I like to keep it nice and clean if possible.
Millemissen
Flensborg, Denmark
Posts 14,680
http://shop.oneremote.dk/catalog/product_info.php?products_id=3654
Greetings Millemissen
Michael
Sweden
Posts 2,578
Michael replied on Mon, May 13 2013 10:32 AM
Millemissen:
Thanks Millemissen! That looks quite nice actually. The only thing is that it cost 1850 SEK, I can buy a used samsung for 100 SEK in sweden, or the Thomson DCI 1500G for 380 SEK inc. shipping from Germany.
I dont want to spend a lot of money on the setup since it is quite old and I have two other TVs. Perhaps I can find a used oneremote, I´ll look into that as well Smile
Page 1 of 1 (3 items) | RSS
