Connect Beogram 7000 to Beocenter 9500
This post has 4 Replies | 0 Followers
Bieele
Posts 395
Bieele Posted: Fri, Jan 3 2014 9:26 PM
Is it possible to connect a beogram 7000 to the phono connection of the beocenter 9500?
Both have an RIAA amplifier, therefore this does not work without any changes (believe me I tried and was happy my speakers were not damaged...). Currently I have connected the beogram to the aux which works okay, but I would like to use this input for another purpose.
Regards,
Bieele
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Jan 3 2014 9:30 PM
it would be easier to attach an aux expander, even a non b&o one....
Ralf
Bieele
Posts 395
Bieele replied on Fri, Jan 3 2014 9:37 PM
Thanks Ralf for the quick reply.
If possible I would like to avoid the expander; is the tape-2 connection an easier solution? I tried that once, but it seemed that that port gives signals that result in strange behavior (for instance: lifting the needle when this connection is selected). Maybe I can "cut" the data line on the aux connection?
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Jan 3 2014 9:57 PM
you can unscrew the two upper pins (6+7) of the beogram cable to cut datalink.
Bieele
Posts 395
Bieele replied on Sat, Jan 4 2014 8:02 AM
Thank you. This sounds like a good solution to connect the beogram to the A-TAPE2 connection. I will give this a try!
Page 1 of 1 (5 items) | RSS
