Store radio channels?
This post has 4 Replies | 2 Followers
UffeT
Posts 13
UffeT Posted: Sun, May 19 2013 8:30 PM
Trying to solve the problem with the combination Beomaster 7000 and Beolink A (not 1000).
It´s not possible for me to store i.e. the channels - the is no "store" button on the Beolink??
Is there any combination to press...??
What to do - I have just bought a Beolink 7000 but it will not reach me this month.
// Uffe
Millemissen
Flensborg, Denmark
Posts 14,680
A BeoLink A ???
If you mean a Beo4, just find and activate 'Store' in 'List'.
Otherwise please explain what a BeoLink A is!
Greetings MM
tournedos
Finland
Posts 7,357
tournedos replied on Sun, May 19 2013 8:53 PM
Terminal A, I suppose. Unfortunately the picture is so small that I can't tell what buttons it has, and I couldn't find it described in any user manuals either. It's possible that it simply doesn't have that function, but equally possible that there is a workaround... hopefully someone knows.
I heartily recommend you get a proper Beolink 1000 anyway. Every B&O owner should have one!
--mika
Playdrv4me
USA
Posts 477
My Beolink 7000 just sits there looking pretty, and my Beo4s rarely get picked up. My "daily driver" has always been the BL1000. Love it.
Millemissen
Flensborg, Denmark
Posts 14,680
Well, the 'Terminal A' was meant - that really is 'oldschool'.
If there is a 'Shift'-button on it, that might help. Have a try, it can't harm!
Greetings MM
Page 1 of 1 (5 items) | RSS
