Hello,
in my BeoCenter 9500 with the tape deck 2, the belts are faulty. I want to change them.
The belts I have, two of them I have easily changed.
Headaches I got in the third, the large flat belt, how do I get there.
In the service manual and the exploded view only the tape deck 1 is available.
Have anyone of you an exploded view drawing from the tape 2?
Thank you in advance
Ingo
BeoVision Eclipse 55“ wallmounted, BeoRemote One BT; BeoSound 9000(ex-weiss), BeoLab 9; BeoLab 8000 rot; Beosound 1 grün; BeoPlay H6; Beo4
Tape 2 - what's that ?
Didn't the belts come with mounting instructions ?
Sorry, I talk about the Beocenter 9500-2 / SW 1.3 -1993 with Cassette Tape Deck 2. Three belts are needed, two square and one flat.
The first of the BeoCenters 9500 was equipped with a cassette tape deck with only one belt.
I buy these belts without mounting instructions:http://www.ebay.de/itm/B-O-Beocenter-9500-2-Riemen-rubber-belts-Kassettendeck-Cassette-Tape-Deck-/130681991191?pt=DE_TV_Video_Audio_Kassettenspieler_Teile&hash=item1e6d40f017
I'm not sure, but I read somewhere that the cassette tape deck 2 is identical that was fitted in the Beosound 2500. Can you confirm this?
PS: My english is not so good, last school hour is about 40 ago
Some parts of the deck is identical to the Beosound 2500 but far fom all.There's only one belt in the Beosound 2500.
I suggest you ask the seller for assistance.
Thanks for the quick reply,is perhaps an exploded view of this cassette deck stored in the database from beoworld?
If so, can someone help me out, or I have to change my member status?
