Having traded up a BV10-46 MKI to a BV11-46, the improvement in picture and audio quality was noticeable. It was a worthy upgrade.
I've spent the last six or so months trying to find a black framed BV10-32, without success. Did anyone actually buy one of these? No dealer has a new or ex-demo unit.
Last week, bought a Jan 2013 ex-demo silver framed BV10-32. Superb. Picture is up there with the BV11-46, if not better, no doubt due to pushing a HD picture through a small 32" screen (small pixels etc).
Anyway, certainly recommended. Thanks to Nick from Hygge Living (http://www.hyggeliving.com), it has been installed on the wall, in my kitchen. Who needs a V1 when you can have a BV10-32?
Best of all, orange fret has been ordered, which should arrive next week :)
A gorgeous little television - I have the silver framed version, currently sporting the orange fret, and with the aluminium BL11.
On a recent trip to La Rochelle, I recall the local B & O shop had a BV10-32 with the black frame and orange fret on display; disappointing if it is no longer available as an option as it looked very stylish.
I have just placed an order for the BL14 (the BL11 will be relocated) and wondering which fret colour to have as the orange fret will have to go!
One disappointment with the BV10-32 however, is the optimal viewing angle which I find quite narrow (mine is first generation, so may have improved with latest display).
Peter
I was talking about the V1 on a STB stand, versus a used 10-32 this very morning. A no brainer.
Peter2: On a recent trip to La Rochelle, I recall the local B & O shop had a BV10-32 with the black frame and orange fret on display; disappointing if it is no longer available as an option as it looked very stylish.
Sir, you tease us with your stories of witnessing a black framed BV10-32 in person :)
Seriously, I looked everywhere. The silver framed one works better than I had expected as the wall is white, which reflects off the frame, masking the shine.
Great set, superb picture, reasonable audio (my BS8 has a wider sound). Pleased.
moxxey:. Who needs a V1 when you can have a BV10-32?
I need a V1, as it perfectly matches my kitchen :-)
hfat
moxxey: I've spent the last six or so months trying to find a black framed BV10-32, without success. Did anyone actually buy one of these? No dealer has a new or ex-demo unit.
hfat:I need a V1, as it perfectly matches my kitchen :-) hfat
Beovision 11-55, BeoPlay V1 40, Beosound 9000, Beolab 8000's and 3 Beocom 5's...
Hi Martin w do you really have 3 forsale?
MartinW:Yes two on display in two stores and one in stock (Newcastle and Yarm UK)
And guess where I'm from originally Martin...? Yarm. Went to school there. Been in your Yarm store a few times.
However, I did get a dealer check and looked online on the B&O stock check and no dealers reported having a black-framed BV10-32 in stock.
