In an other thread a describe a problem with interaction between BeoTime and MLGW. A Basic question for the other thread is here:
Can BV11 receive BeoTime LIGHT commands and transfer it to mlgw?
Yes it can. But I think you have to enable mlgw function in BV menu...
your BV sw must be build 10.0.3.30552 and set power sving mode to off.
You can watch IR function in mlgw webinterface monitor tool.
Stefan
Thank you Stefan, I have the same sw version and BV11 is connected to MLGW.
