Beovision Avant DVD tube adjustment???
This post has 4 Replies | 0 Followers
Chaka
Chicago
Posts 312
Chaka Posted: Sat, Jun 8 2013 9:11 AM
Hi, I was offered a Mk III DVD RF Avant, but was concerned about something.
On the left side of the screen, there is a 3 mm gap (vertically) where the picture does not meet the black border of the screen (a 3 mm greyish strip).
Is this a simple adjustment, or something worse?
Just wondering if anyone had the same issue or may know what the problem is.
Thank you very much.
Langleyav
Windsor UK
Posts 226
That sounds like under-scanning of the picture tube. It can usually be corrected in the service menu with the horizontal phase and amplitude controls
Ron
Chaka
Chicago
Posts 312
Chaka replied on Sat, Jun 8 2013 2:27 PM
Thank you very much Ron.  Can I please ask how you access the service menu?
Langleyav
Windsor UK
Posts 226
There are some very critical adjustments in the service menu and access to it is retricted.
Try and get a B&O engineer to do it, as much damage can be done if you don't have the test gear to do the adjustment properly.
Ron
Chaka
Chicago
Posts 312
Chaka replied on Sun, Jun 9 2013 1:19 AM
Thank you Ron.  Much appreciated.  Enjoy your weekend.
Page 1 of 1 (5 items) | RSS
