Beosound Century
This post has 6 Replies | 0 Followers
iiirshad
Posts 25
iiirshad Posted: Wed, Oct 24 2012 10:06 AM
HI! i got a BS Century but did not have remote to test it at the time of buying when i got the remote it just doesn't respond at all. I already activated the remote function on the Century ( press standby>sound>1>store) then cleaned the IR sensor,still no response. .Can i just change the remote sensor  ? Any suggestions,please.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Oct 24 2012 10:20 AM
According to the workshop manual, Sound-1-Store disables the remote function.
It is activated by Sound-0-Store.
hemenex
Posts 569
hemenex replied on Wed, Oct 24 2012 3:05 PM
Guy:
Yes, so does my printed version tell, too.
BUT the german setup tells it's just the other way round - and YES, that is true.
I tried it on my century and definitely SOUND 1 STORE does ENABLE remote, SOUND 0 STORE does DISABLE.
So that's not iirshad's problem Sad
  Gunther
Steffen
Denmark
Posts 1,408
Steffen replied on Wed, Oct 24 2012 11:50 PM
Hi there.
Is it still not working?
I bought a Century a few months ago - and it has a rather strange behaviour....Hmm
When I plug it to mains, it doesn't respond to the remote immediately. But when it has been plugged for half an hour or so - then suddently it responds to the remote and so it does hereafter. I can even turn it off (standby) and turn it on again with the remote -as long as the main is plugged.
If I pull the plug and plug it in the day after, then the same happens again - only after half an hour it responds to the remote again.
Very strange...Confused
Søren Mexico
Mexico City
Posts 6,411
Steffen:
Hi there.
There must be a small battery for the memory functions, check it or change it.
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Oct 25 2012 9:22 PM
Thank You, Søren. I'll check that when I get the time. Until then, I'll just keep it plugged in.
Pius Steinger
Schweiz
Posts 13
Hi iiirishad
could you solve the problem, that the century had no reaction on the remote control?
I have the same problem. it works a long time, but now, no action if I put something on the remote control, but it works with other b&o systems.
thank you
Page 1 of 1 (7 items) | RSS
