Hello,
I have a Beovision Avant 32 (from 1997 I think) and still using it and enjoying it.
I am using it with a Sky decoder, and no problem about it. Now I added a DTT decoder and here is my problem: I would like to use both decoders, but in my epxerience each decoder is recognized only in the central top scart slot. I tried plugging one of the two scart to the left slot, but I do not know how to acess it.
Hence at the moment I have to keep plugging and unplugging each decorder in the central slot in order to watch either Sky decoder or the DTT decoder. I simply switch the decoder on and the tv automatically shows its programs.
But how to have both decoders connected at the same time and switch the connection between one and the other?Thanks for your help,
Cesare
ps: I also tried the right slot (videotape) and I can only hear sounds but no video.pps: I also tried to connect the Sky decoder with RCA plugs connecting in the top left on the back of the tv: still do not know how to switch to this signal
