POWERLINK WHITH 1741
Geurink
Posts 18
Geurink Posted: Fri, Jun 21 2013 3:53 PM
Hello,
I have a sound system 9000 and additional some power link amplifiers type 1741.
Its al function correct but is it possible to get an on\off and volume control only on the connected 1741 amplifier?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Jun 21 2013 4:30 PM
That's possible if you use an additional ML active. This small box has it's own ir-eye for control and powerlink to attach the MCL-2P.
You only need an extra ML cable to link the BS9000 (6 discs?) with the ML Active.
The above mentioned solution works only if the system has a ML connection.
Page 1 of 1 (2 items) | RSS
