One of our Beovox S75 B&O speaker has a broken tweeter. It´s a PEERLESS KO10DT.http://www.audioasylum.com/audio/speakers/messages/30/308013.htmlVery often i find this tweeter with 8 Ohm. But on the backside of the broken one it´s writen "+4 Ohm 17" and "808.16"
Do you know any alternative tweeter which is not to expansive and available in europe?On the back side of the Beovox S75 it´s written " 75(100)W, 4Ohm"Would a 8Ohm tweeter work in this speakers?The speakers work on a Onkyo TX-7530 Tuner.Thanks for your help. hifilaie, Switzerland
Hi! I have the same question if it works because i have found https://www.monacor.com/en-gb/monacor/products/pa-technology/speaker-technology/hi-fi-tweeters/dt-100/ which is exactly replacemnt for peerless ko10dt. But is 8 ohm...:( Ask +dillen in forum if it ok to replace it.
Cheers, Ovidiu
