hi all I had planed to buy the DM800HD but after some research the DM800HD se appeared to be the receiver to buy. I moved on further in the search for a receiver and found the hybrid 3x1 Tuner: DVB-S2,DVB-C, DVB-T which I bought still a DM800HD se. Problem is it will not work with beo eye. Is there any info on how to get DM800HD se to work with the beo eye . Any help appreciated
