Broken Beogram 3404 cover hinge
This post has 6 Replies | 0 Followers
Mark2000
Posts 4
Mark2000 Posted: Tue, Apr 10 2012 12:11 AM
Well, I really did it this time. The cover of my Beogram 3404 seemed to be loosening on one side as the cover wouldn't come down completely on the right. Instead of doing to sensible thing and just tightening the screw on that side I decided to remove it all together to see if there was a bigger problem to be fixed. That's when the spring loaded thing flew out at me.
I have NO idea how to get this back on. I'm including pictures of the carnage. If anyone has instructions, experience, or diagrams for this I'd be very grateful. I'd hate to check this perfectly working turntable.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Apr 10 2012 8:24 AM
It's not too difficult if you know how and we can guide you.
But first check the right hinge part of the dustcover for cracks and breaks. Early symptoms
of a broken hinge is exactly difficulties when closing since the lid will sit slightly too far forward and
eventually hit the rear edge of the sloping front panel.
Mark2000
Posts 4
Mark2000 replied on Tue, Apr 10 2012 7:08 PM
Yes, you're correct. The small hinge on the right side is starting to crack, though is not cracked all the way through. I can see the cracks, but pulling on the hinge doesn't cause any separation.
Dillen
Posts 13,191
Dillen replied on Tue, Apr 10 2012 9:34 PM
I suggest you drill through the broken pieces and glue in a tiny steel pin or two to strengthen the part.
Mark2000
Posts 4
Mark2000 replied on Thu, Apr 12 2012 5:20 AM
That's probably out of technical ability and bag of tools, unfortunately.
Søren Mexico
Mexico City
Posts 6,411
Mark2000:
Find a mechanics workshop, make copy in steel, paint black
Mark2000
Posts 4
Mark2000 replied on Fri, Apr 13 2012 6:25 PM
Ok, so assuming I can repair the top, how do I reconnect it to the turntable?
Page 1 of 1 (7 items) | RSS
