Connecting CDX2 to Beovision 6-22? - now fixed
Dave Farr
France
Posts 2,283
Dave Farr Posted: Mon, Jul 15 2013 10:12 AM
Dear all,
first off, is this possible?
I have a spare Beogram CDX2 I would like to connect to a Beovision 6-22 in my daughter's bedroom.  The CDX has RCA outputs.  The Beovision has L+R RCA inputs (for PC according to the user manual) and of course the AV 21 pin SCART input.  I've tried all sorts and can't get it to work.  Any ideas on how to connect these two?
Many thanks in anticipation,
Dave.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Mon, Jul 15 2013 1:25 PM
The BV6-22 has camcord RCA' on the leftside. Try that with using the Camcord instruction on the Beo4. Normally, the Bv6 will switch automatically after connecting a videosource to it's Cam RCA's, but because there isn't any signal on it's videocomposite RCA, it doesn't switch by itself. So, have to help it a little.
A alternative would be using the Scart on the back.
After getting sound, you should/could set the BV in the AV-(source). Picture will then be muted.
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Jul 15 2013 1:40 PM
Sorted!
I was using the camcorder option but the moral to this tale is to not trust a 15 year old.  The CD being used was a CD-R which was supposedly recorded but was in fact BLANK.  Serves me right for not checking first!
Thanks to Matt at Lifestyle-AV and Beobuddy.
Dave.
Beobuddy
Posts 3,972
Beobuddy replied on Mon, Jul 15 2013 2:22 PM
That's probably one of the few 15yrs old that know s what a cd is Big Smile The lot are using mp3's instead of cd's, I guess.
Page 1 of 1 (4 items) | RSS
