HI I have a bv7 mk3 and have just picked up a mk1 beo4 remote with sat av to use as a spare,
I have managed to get the tv button to control my apple tv fine and the sat button controlling my sky box, but I am stuck as to getting the av button to control the built in dvd player.
Sorry I also did try and find the software version of the remote but for some reason when i press the go menu together then list nothing happens so i would be gratful if anyone know how to do this also.
Many thanks in advance
The 'AV button' does not work this way.
Look in 'List' for 'CDV' and add it.
Depending on the SW version on the Beo4 you can move it too - to be one of the first entries in 'List'.
Greetings Millemissen
The SW version is not important - since you can not update it yourself.
The 'AV' button was used earlier to redirect the sound from the Audiosystem to the (linked) Videosystem and vice versa.
It is nowadays mostly used for selecting the audio in a videosoure without turning on the picture,
and it was put in the 'List' long ago to give room for the 'DVD' button (with a new SW on later BEO4's).
