Hello,
A newsletter from dbPowerAmp introduces a brilliant software to retrieve cover arts from the Internet:
http://www.dbpoweramp.com/perfecttunes.htm
Since dbPowerAmp ( http://www.dbpoweramp.com/dmc.htm ) is a very good ripping software, I tried the demo version, which is, IMHO, user friendly and efficient.
Just a question, what is the optimal image size for a use with BS5, Beoplayer and the various softwares for IPhone/Ipad?
Should I go for the biggest image size available (sometimes 1400x1400), or set a limit to a smaller size?Thanks for your help and kind regards,
Yann
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Some servers have problems with artwork that is too big.
My advice usually is 600x600.
Please try with your favorite server and controlpoint (app) to find of what is best for you.
Greetings Millemissen
Thanks for the tip.
Tried Bliss, tags are OK but the "Folder" file has not been updated.
Kind regards,
Yann.
