Hi
The cable between my beosound 5 and the beomaster 5 is too short for my need.
According to you, is there any solution in order to put the beomaster 5 15 or 20 meters from the beosound 5 ?
Best regards
Olivier
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Hi olvisab,
you can get a so-called 'BeoSound 5 Cable Extender', which makes it possible to have a distance up to 40 meters between master-5 and sound-5.
Please ask your dealer for details.
Twice posted!.
9 meter would be too short too.
Thanks Millemissen for this precious information
http://dk.mp3gear.dk/product.asp?id=995
http://dk.mp3gear.dk/product.asp?id=996
I Montet beomaster 5 in BeoVision 9 and have used these cables to 15 meters,
the electric cord was cut and joined with a simple cable op to 15m
