Looking for some feedback...I am thinking of connecting my beolab 1s to my BV11. However the characteristics on the BV11 speakers seem very different than the bl1 (brighter sound). Do you think this would provide an improvement overall, or would BL14 2.1 setup be a better match?
Also for the second part of the question, any suggested configuration with the BS9000? Should I just connect each speaker to both the BV11 and the BS9000, or some other configuration that would provide an added benefit.
Thanks in advance for any feedback...
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
You won't know till you give it a try....3 speakers are going to be better then one speaker! And will add some widenees and depth to the sound image....Also you have a much bettter sound setting in the BV11 that you can play with...
Please post how you get on?
