Beovox S75 Mid Range Dome Replacement
Midas
Posts 1
Midas Posted: Fri, Aug 23 2013 11:39 PM
Need to replace one of my S75's Mid Range Dome speaker. (AD 0211/SQ4)
Can anyone tell me if the mid range speaker in the S60's is the same Mid speaker that was used in the 75's?
I have an opportunity to purchase  mid range part #AD0210/SQ4.  I think it came from a pair of S60's and would like to use one to replace the mid in one of my S75's.
Any and all help would be appreciated.
Søren Hammer
Denmark
Posts 953
The domes from the S60's and S75's are identical
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Aug 25 2013 10:33 AM
I seem to remember the part numbers being different, one being a 4 Ohm driver and the other 8 Ohm but
I'm not 100% sure.
BTW it's not a true midrange driver, merely a "filler" or "phase-link" unit. In most cases it won't play
much and it may not be immediately obvious if it's broken or working but you can usually tell a difference if
you disconnect it.
Page 1 of 1 (3 items) | RSS
