hallo,
in the service menu under picture adjustments you can control the behavior of the backlight and the edge light.
setting 1 and 2 will switch it off and 3 and 4 on. 3 is default in my tv.
the intensity can be controlled too.
but it will change the behavior in a light room as well.
in my eyes the sensor of the tv does not recognize dark rooms right in connection with the edge lighting.
grüße horst
