DIN pin replacement
Piaf
Victoria, British Columbia Canada
Posts 2,639
Piaf Posted: Sun, Oct 6 2013 12:17 AM
I would like to connect a Beogram 4004 to a BeoCenter 9000; so first off, will this combination work with the limited remote functions of the 4004?
I am sure my Beogram 8002 would be a more natural combination, but it came with RCA plugs, so the remote feature is not possible.
If the BG4004 is compatible with the BC9000 is it possible to replace the two missing pins in the DIN connector? If it is, how do you do this?
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century,  S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase,  B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Søren Hammer
Denmark
Posts 953
The Beogram 4004 can't understand modern Datalink codes I'm afraid.
The Beogram 8002 cable can be detached from the back of the turntable, just find another double shielded cable to plug right in Smile
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Piaf
Posts 2,639
Piaf replied on Sun, Oct 6 2013 1:24 AM
I was afraid that would be the answer due to the age of the BG 4004. Thanks Søren for the suggestion vis-à-vis the BG 8002. Yes - thumbs up I'll look into this.
Jeff
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Soundsheavenly, who advertise at the bottom of most pages of the forum, can supply the correct cable for your 8002.
Regards Graham
Page 1 of 1 (4 items) | RSS
