I've recently acquired a pair of CX100 bookshelf speakers, along with a beocenter 9000 and a beogram, however the center is broken and I'll be selling it for spares or repair as it is far beyond my ability to fix. I hope to get the speakers working. I'd like to be able to play LPs from the beogram onto them and also be able to plug my ipod/laptop into them. I've been told that since they are passive speakers I need a slave amp. I'm entirely ignorant when it comes to technology and if anyone helps could they please explain as if to a child. I'm wondering what amp I need, and I only have a price range of about £40 preferably less. I only really want the speakers for listening to music in my room so don't need them to be massively powerful. Any advice on how to set this up and could you suggest an amp to me that could be used as a slave?
Thanks for any help in advance
Maybe some Tripath amp? I'm very pleased with one in computer use.
But if you are connecting more that one source, you need preamplifier with inputselector, and whats more, if you are connecting Beogram in it, it will need RIAA amp in it
Or something like Beolab 1700?
I have a Beogram 9000. I've talked to some guys in stores and I'm told I need a 20W amp upwards and would need one with a built in phonograph for the beogram to work with it. I could get a separate one but want to keep it as cheap as possible. From what I've seen through only the really expensive £100+ amps seem to have one built in. I was looking at something like this http://www.amazon.co.uk/TA2020-Tripath-Class-T-Amplifier-Supply/dp/B007VMA6OU/ref=sr_1_1?ie=UTF8&qid=1377709851&sr=8-1&keywords=stereo+amplifier any idea if that would be any good and then I could get a separate phonograph?? It would be greatly appreciated if anyone was able to link me a stereo amp in the £40 range that would be able to do everything I'm looking for as I'm struggling to find one myself and I'm worried about getting the wrong type.
I'm also worried about the connections, the CX100 speakers I have have a "ball and blade" connection I believe it's called and was wondering if this would be able to plug into a new amp or if I'd need a converter??
Thanks a lot
http://www.beoworld.org/prod_details.asp?pid=308 Doesn't seem to say anything about a RIAA being built in. What does this mean? Could you suggest any amps I would be able to use with it, or does this mean I have to buy something additional. The guys in the store said I may have to get a http://www.maplin.co.uk/stereo-phono-pre-amplifier-28732
Well, I would buy second hand older amplifier, otherwise you have a lot fo small boxes witch is not nice (imo).
Connectors are not problem, I'm sure, for example Maplin have them (DIN speaker connetor). You will also need DIN female to phono male adapter between Boegram and RIAA preamp, if you end up one like Maplins.
So, form Beogram > RIAA preamp > amp (Tripath?) > speakers.
