Control BV11 over LAN
This post has 2 Replies | 2 Followers
Hermann_
Posts 52
Hermann_ Posted: Sun, Aug 25 2013 11:57 AM
Hi together
I have a home automation system (command fusion). Therefore I made for my iPad a graphic use interface (GUI). Now I can control my light in my home. When I push a button iPad, I string goes over the LAN to my home system infrastructure and switched on/off the light.
My thoughts: Can I extend this system, so that I can control my Beovision 11 in the same GUI - BV11 is already connected to my LAN. Is therefore a possibility to send a string (command) over the Ethernet for controlling BV11? When yes, where can I find or get all the commands?
Thanks in advance, Hermann
berlin2010
Posts 92
Seeing as there's already an official iPad remote control app, clearly the BV11 can be controlled over LAN/WLAN. As to where to get the commands, that's not so obvious.
mjmedlo
Posts 922
mjmedlo replied on Mon, Sep 2 2013 1:55 PM
Add a master link gateway and you can simply send signals to it.
I don't think they've released the LAN protocol yet for bv11
Page 1 of 1 (3 items) | RSS
