Beocenter 7007 problem with sound
spoonertunes
Posts 5
spoonertunes Posted: Mon, Sep 2 2013 7:01 PM
Hi all. Ive just got hold of a Beocentre 7007 with speakers. When I turn the power on everything seems to work fine, except that is for the sound. There is no sound coming from the speakers or the headphone output. If I turn the system up to its highest volume I can hear the music but only very quietly! Anybody know if this is an easy fix or not please before i start to unscrew things!
Thanks in advance,
Rob.
solderon29
U.K.West Midlands
Posts 764
Have a look at the rear tilt up connection panel.There should be a round blanking plug fitted into a socket.If it's missing,that's your problem.It's a linking connector,but user's often remove it to connect,say an i'pod or similar device.If it's missing and lost,you can make a replacement with a 5 pin din plug.
Regards,
Nick
spoonertunes
Posts 5
Hi Nick,
Ive checked the rear panel that you mentioned and there is no sign of a blanking plug but there is nowhere I can see where a blanking plug would go! I tried uploading a photo but It wont save my upload!! Below is a list of all the inputs/outputs on the panel if that helps and maybe you could point me a bit further in the right direction if you dont mind:-
Looking from left to right:-
Speakers 1 L/R
Speakers 2 L/R
AM (weird 2 pin plug)
FM Aerial
FM 240 - 300
LINE IN/OUT (7 pin plug)
Tape 2 Play L/R and record L/R
Any further help would be much appreciated,
Thanks,
Rob.
Page 1 of 1 (3 items) | RSS
